I would like to get a basic capture card to convert VHS to DVD. I was going to buy a card with a TV Tuner as well for around £40 in the UK. Will my system spec be ok for doing this?
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp2.030422-1633)
Processor: AMD Athlon(tm) Processor, MMX, 3DNow, ~1.0GHz
Memory: 256MB RAM (around 71% of this is usually in use)
Page File: 275MB used, 727MB available
Card name: NVIDIA RIVA TNT2 Model 64
Manufacturer: NVIDIA
Chip type: RIVA TNT2 Model 64/Model 64 Pro
Thanks,
Toss
Probably, but it may be close.
Can you take it back if it doesn't work ?
Cant get either video capture card to work
By ralphey in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 21:02 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Would an older capture card work on a Vista PC?
By Rein Engel in forum Capturing and VCRReplies: 15Last Post: 23rd Jun 2007, 12:33 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
