When for example ripping a DVD, the video (or the audio in some cases) comes out as multple files. I understand that this is because of a file size limitaton or something in the OS, but does this mean that I have to do something tricky to join the files together before I can use them as an input for editing etc.?
Specifically, I have ripped the PCM soundtrack from a concert DVD and I wish to do some editing of it in GoldWave. The soundtrack has come off the DVD in two files - but it's all one continous audio stream.
Is there a tag at the end of the first file which says something like "now go to 'file 2'" for example? If not then how do I instruct GoldWave to look for the second part of the audio track?
DVDdecrypter has a mode where the video and audio will be
ripped all in one file.
Vobedit will rip audio or video from a set of VOBs into contiguous files
DVD2AVI will rip the audio to a single file -
Could you please tell me how this is done with DVD Decrypter?Originally Posted by FOO
I have got the DVD with the PCM audio track in the DVD drive, I load DVD Decrypter, select IFO Mode, Under settings for IFO mode I select File Splitting = none, under stream processing I deselect everything except the PCM audio track, I check Demux and press the big button to rip it.
What I get out is a VOB file. I was expecting a WAV file. What have I done wrong?
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 12:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
i need help with a strange thing about frames in mpeg files...
By DjSonicx in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2009, 15:22 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28
