I wanted to try one of my DVDs that didn't need to be re-encoded to fit on a DVDR. JP3 fits neatly on one DVDR - so I tried that first. I used DVDdecryptor to rip the DVD and then Nero 5.5.10.54 to burn it. I used the DVD VIDEO setting and put all of the files into the VIDEO_TS folder. There were 5 .VOB files and one .IFO file. The burn completed sucesfully and I tired to put it in out standalone player and it didn't work "Can't play DVD". I'll get the exact model number when I'm back at home.
I tired it in my Liteon 8x DVDrom and it sees the DVD and can read the files, but it will not play in WinDVD. If I manually select a VOB file off of the DVDR in WinDVD it will play it. So it looks like it can see the data - it just doesn't seem to recognize it as a Video DVD.
DVD INFO sheet for DVDR:
Media Information
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID RICOHJPNR01
Format Type UDF 1.02
Volume Name JURRASICPARK3
Application id
Implementation id AHEAD Nero
Recording Date/Time (mm/dd/yyyy) 12/ 9/2003 3:06:11
Format Capacity 4.28GB(4.60GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 1.0x 1412KBps
Data area starting sector 30000h
Data area end sector 223E9Fh
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
UDF is 1.02 (I guess Nero fixed that a while ago), so I don't think that is a problem. Any ideas?
I'm running XP and the latest version of Nero 5.5. My Sony DVDRU510 has been flashed to 2.0G.
Unless u use DVD Decrypter in ISO mode, you can't just rip and burn. When using IFO or FILE modes, the files must be processed/compressed first with something like DVD Shrink or DVD2One. The resulting files can then be burnt using Nero in DVD-Video mode.
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 10:31 -
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 21:35 -
DVD to DVDR DL problems
By Martin_S in forum DVD RippingReplies: 14Last Post: 7th May 2008, 19:47 -
GO DVD Sima with a VCR & DVDR - help hooking up.
By lee harvey oswald in forum Newbie / General discussionsReplies: 1Last Post: 11th Dec 2007, 13:10 -
nero 8 & dvd shrink
By jerbevpicasso in forum Newbie / General discussionsReplies: 17Last Post: 24th Oct 2007, 21:36
