I have had a problem with 2 sets I was trying to put onto dvd using svcd2dvd and have had about 5 work ok. I am new to this and am thinking it is due to one of the mpg files. Just need to know how to fix it so I can move on . I have posted one of the logs. Other than this the programme is great. Thanks chrissyboy!
############### New MPEG File ###############
File: G:\dd\part20.mpg
Type: VCD
Horizontal Res: 352
Standard: PAL
Audio SampleRate: 44100
******** Demultipexing original mpg file
(Total size: 196MB, Duration: 00:02:12, Rate(MB/Min): 88.53)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 31MB, Duration: 00:00:36, Rate(MB/Min): 51.66)
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] File G:\dd\part20_DVD.mpv unrecogniseable!
INFO: [mplex] File G:\dd\part20_DVD.mpa looks like an MPEG Audio stream.
**ERROR: [mplex] Unrecogniseable file(s)... exiting.
System.IO.FileNotFoundException: Could not find file "G:\dd\part20_DVD.mpg".
File name: "G:\dd\part20_DVD.mpg"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileInfo.get_Length()
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
If you need the whole log I can post
BiggvmorecognizeGuest
Looks like a dodgy mpg. What version are you running? In v1.5.2003 there is a mpg fixer which should solve this for you. Also did you start with BINs or MPGs?
Used the fixing tool - it hasnt worked - still stopped at the same place. I took the file out and left the fixed one - I am presuming thats what you are meant to do. I have attached the log again and the fixing mpg log.
File: G:\dd\part20_FIXED.mpg
Type: VCD
Horizontal Res: 352
Standard: PAL
(Total size: 196MB, Duration: 00:01:10, Rate(MB/Min): 166.62)
(Total size: 31MB, Duration: 00:00:40, Rate(MB/Min): 46.41)
**ERROR: [mplex] File G:\dd\part20_FIXED_DVD.mpv unrecogniseable!
INFO: [mplex] File G:\dd\part20_FIXED_DVD.mpa looks like an MPEG Audio stream.
System.IO.FileNotFoundException: Could not find file "G:\dd\part20_FIXED_DVD.mpg".
File name: "G:\dd\part20_FIXED_DVD.mpg"
at _S_VCD2DVDMPG.frmMain.Mux(MpegFile mpeg)
at _S_VCD2DVDMPG.frmMain.ExecuteProcess()
And the fixing mpg log
VCDGear 1.76 final build 031211 coded by Dracore (vcdgear@hotmail.com)
Testing and quality control by MACKerMD
Language: English
Version: 3.50 - Jan. 1, 2003
Translation by: Dracore
processing method :: (mpg2mpg)
.mpg src(In) -> G:\Documents and Settings\Computer User\My Documents\shit\part20.mpg
.mpg dest(Out) -> G:\Documents and Settings\Computer User\My Documents\shit\part20-FIXED.mpg
Fix MPEG Errors
# -> searching
Setting read size to: 2324
Setting write size to: 2324
# -> writing...
# 0%
# 0 MPEG block correction(s) applied
# 2 Blocks padded
# OK!
Capture megavideo from the middle of the film
By TTY in forum Video Streaming DownloadingReplies: 5Last Post: 2nd Jan 2012, 14:32 -
Philips DVP3982-37 AVI playback stops in middle
By BKN6006 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Mar 2010, 16:43 -
missing subtitles in the middle of the movie
By steapien in forum SubtitleReplies: 5Last Post: 13th Dec 2009, 22:17 -
Middle Surround
By ranosb in forum AudioReplies: 0Last Post: 27th Jul 2009, 17:35 -
shutdown in the middle of ConvertX
By doodoobrova in forum Authoring (DVD)Replies: 3Last Post: 8th Feb 2008, 19:32
