Hello, I just tryed to convert my DV video of 10 seonds-which will be first play, and I am using TMPGEnc plus and DVD PLA wizard CBR 6000.
Converted video is perfect just one thing is bad...original in DV is 720 x576 and converted MPEG 2 is 768x576.
I am using TMPGEnc for a long time but this is first time to happend.
Does anyone had something like me before.
Tnaks for your help
768x576 is the resolution that it should display on your computer monitor to make it the correct resolution.
the resolution that dvds are encoded are the same whether it's 4x3 (rectangle tv) or 16x9 (widescreen tv). 720x576 is the res that pal dvd uses, and, to display properly on your computer, it will either stretch it horizontally if it's widescreen, or stretch it vertically if it is 4x3.
so simply put, it is just resizing the image to display in the proper shape.asdf
Capturing From VHS Via VirtualDub Produce Strange Result
By max20d in forum Capturing and VCRReplies: 0Last Post: 8th Oct 2010, 22:55 -
Tmpgenc Express rendering real video, result no sound
By pcb in forum Newbie / General discussionsReplies: 0Last Post: 31st May 2008, 14:17 -
mpeg2enc and subtitles: strange result.
By Levina in forum ffmpegX general discussionReplies: 5Last Post: 27th Mar 2008, 16:08 -
strange codec needed
By bountylord in forum Software PlayingReplies: 1Last Post: 8th Mar 2008, 10:40 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
