After ripping the vob files off the i used dvd2avi to create a d2v file and decode a wav file for audio so i could convert with tmpgenc (what i always do). So some unknown reason when the process finishes there is only a d2v file and no wav file, ive checked that its select as decode to wav too. one thing i did notice which i hadnt seen before is when the vob files are being processed it displays the audio as "mpeg audio", could this be the problem? , if so how do i fix it?
i think those files are illigal by now.. and that is why you wouldnt' have with any know codecs..
there is however solution.. but i do not know if i am able to write about it at this forum... do not want to be kick..out
FFMPEG decoding WMV to FLV problems
By motorg in forum Video ConversionReplies: 3Last Post: 10th Aug 2009, 22:30 -
Problems decoding FLV4/VP62
By drwho in forum Video ConversionReplies: 1Last Post: 1st Mar 2008, 19:16 -
DVD decoding problems with TMPGEnc 3.0 XPress
By shorto in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2007, 13:16 -
DirectShowSource() reliability problems for DV decoding in AviSynth().
By towtruck in forum Video ConversionReplies: 4Last Post: 28th May 2007, 10:43
