Closed Thread
    Apr 2002
    australia,brisbane
    Release Notes
    Version Number: 6.3.0.0
    Changes from Nero 6.0.0.28 to 6.3.0.0
    Features Added
    Added support for new recorders
    Nero StartSmart:
    Added property pages in the configure part
    Added a property page for displaying serial numbers in Nero ProductCenter
    Nero SoundTrax:
    The last folder used for audio clips will now be remembered
    Nero BackItUp:
    BackItUp files can now be opened from the Welcome Window.
    The dialog that appears when double clicking on an entry in the Last Backups list of the Welcome Window has an additional button for ‘Job’.
    Doted lines are now used to mark active items in the two list controls of the Welcome Window.
    Cancel button will be turned to “Finish” button on status dialogs.
    “Finish” buttons of the Wizard has been changed to “Backup” and “Restore” accordingly with new icons.
    The Welcome Page of the wizard will only be displayed in case of a new backup.
    A success message box will be displayed when the user clicks on the “Finish” button of the Job Wizard.
    An additional status column is available in the Job Window that tells whether the job had been executed successful or not ; with time stamp.
    A new “open file dialog” with the last backup list is now available in the Restore Wizard.
    The log file of the burn process can be added to the BackItUp Log and old log file can be destroyed using a new options in the preferences.
    A new source page has been added in the backup wizard. It can be used in order to continue an old backup more easier.
    StartSmart can now launch Backup, Restore or Drive Backup windows directly, in the expert mode.
    All items will be selected by default when creating a job from an existing backup.
    “Date/Time” text on the finish page of the job wizard has been replaced with “Next run”.
    Root icon and drive icons are changed in the restore view.
    Hot plugging of recorders is supported.
    CD-RW can be erased automatically during a backup process by activating an option in the preferences.
    If a recorder is already in use, BackItUp will display a message in the og window and wait.
    Added an option in the preferences, to disable disc eject at the end of burn process.
    Added support for HD-BURN recorders.
    A ReadMe file will be written on every disc, in order to tell where the *.nbi file can be located.
    Nero ImageDrive:
    Added support for images with sub-channels data
    Bug Fixes
    Nero Burning ROM:
    Fixed recognizing FAT formatted DVD-RAMs in disc info dialog
    Fixed “Command sequence error” in case of simulating on DVD-R more than 1GB or in DVD high-compatibility mode
    Fixed wrong free capacity calculation when burning to the image recorder
    Nero BackItUp:
    Fixed backup and restore of a bootable partition is working, but HDD isn't bootable anymore
    Fixed restoring of W9x OS in multiple boot environment results in a non bootable OS
    Fixed burning on HD-BURN media
    Display a warning if the DOS boot image file is not present when performing a drive backup
    Fixed wrong message if the disc is not empty
    Nero StartSmart:
    Fixed not complete German text of StartSmart
    Nero API:
    Set burn lock when writing in burn-at-once mode
    Improvements of error reporting
