Release Notes
Version Number: 6.3.0.0
Changes from Nero 6.0.0.28 to 6.3.0.0
Features Added
Added support for new recorders
Nero StartSmart:
Added property pages in the configure part
Added a property page for displaying serial numbers in Nero ProductCenter
Nero SoundTrax:
The last folder used for audio clips will now be remembered
Nero BackItUp:
BackItUp files can now be opened from the Welcome Window.
The dialog that appears when double clicking on an entry in the Last Backups list of the Welcome Window has an additional button for ‘Job’.
Doted lines are now used to mark active items in the two list controls of the Welcome Window.
Cancel button will be turned to “Finish” button on status dialogs.
“Finish” buttons of the Wizard has been changed to “Backup” and “Restore” accordingly with new icons.
The Welcome Page of the wizard will only be displayed in case of a new backup.
A success message box will be displayed when the user clicks on the “Finish” button of the Job Wizard.
An additional status column is available in the Job Window that tells whether the job had been executed successful or not ; with time stamp.
A new “open file dialog” with the last backup list is now available in the Restore Wizard.
The log file of the burn process can be added to the BackItUp Log and old log file can be destroyed using a new options in the preferences.
A new source page has been added in the backup wizard. It can be used in order to continue an old backup more easier.
StartSmart can now launch Backup, Restore or Drive Backup windows directly, in the expert mode.
All items will be selected by default when creating a job from an existing backup.
“Date/Time” text on the finish page of the job wizard has been replaced with “Next run”.
Root icon and drive icons are changed in the restore view.
Hot plugging of recorders is supported.
CD-RW can be erased automatically during a backup process by activating an option in the preferences.
If a recorder is already in use, BackItUp will display a message in the og window and wait.
Added an option in the preferences, to disable disc eject at the end of burn process.
Added support for HD-BURN recorders.
A ReadMe file will be written on every disc, in order to tell where the *.nbi file can be located.
Nero ImageDrive:
Added support for images with sub-channels data
Bug Fixes
Nero Burning ROM:
Fixed recognizing FAT formatted DVD-RAMs in disc info dialog
Fixed “Command sequence error” in case of simulating on DVD-R more than 1GB or in DVD high-compatibility mode
Fixed wrong free capacity calculation when burning to the image recorder
Nero BackItUp:
Fixed backup and restore of a bootable partition is working, but HDD isn't bootable anymore
Fixed restoring of W9x OS in multiple boot environment results in a non bootable OS
Fixed burning on HD-BURN media
Display a warning if the DOS boot image file is not present when performing a drive backup
Fixed wrong message if the disc is not empty
Nero StartSmart:
Fixed not complete German text of StartSmart
Nero API:
Set burn lock when writing in burn-at-once mode
Improvements of error reporting
Results 1 to 1 of 1
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
