When I try to load the bin/cue in VCD GEAR..it comes up w/a message that "MODE-1 Mpeg extraction not supported" what exactly does this mean and how do i go about fixing it? thanks in advance.....
What version of VCDGear are you using? Are you using VCDGear v3.55 (GUI) http://www.vcdgear.com/files/vcdgear355.zip? Also copy and paste what the cue file says here.
You can also watche .bin files directly in a player called VideoLanClient.
Here is a link to the d/l http://www.videolan.org/pub/videolan/vlc/0.6.2/win32/vlc-0.6.2-win32.exe
Load up the bin file in there and see if it will play, just to make sure your bin file is okay.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
