Hi.
I have the TDK DVD+/-RW RTL KIT - Black DVW+A040212N
have just purchased 10 intenso blanc DVD- r and they do not work,
does any1 here have the same writer that could recommend which discs will work with it,
thanx in advance!!!
Results 1 to 1 of 1
DVD writer doesn't work
By kamyogi in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Apr 2011, 11:43 -
Anyone tried or had good luck with these TDK Dual Layer discs?
By terryj in forum MediaReplies: 2Last Post: 14th Feb 2010, 05:02 -
Prototype HD DVD-R Writer seems to work fine.
By videopoo in forum Authoring (DVD)Replies: 3Last Post: 31st Dec 2007, 18:52 -
DVD-R discs work and then fail in Panasonic DMR E85H
By herefordjw in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Aug 2007, 12:09 -
Sony and TDK DVD Discs
By Happs in forum MediaReplies: 14Last Post: 29th Jul 2007, 15:43
