Not exactly sure what to do at this point. I've followed the directions on this page up to the point where it says to launch Virtuadub and then go to file and capture AVI.
This is the page:
http://www.vcdhelp.com/mjpeg.htm
When I do this I am told I don't have a capture driver. Help!
Thanks.
Results 1 to 9 of 9
i have the same problem. need the VFW drivers. Win2000 i think has them and i'm not sure about others. i know WinMe doesn't. i've just about given up on obtaining them unless i reformat my drive and put Win2000 on if that OS has it. someone posted on here a way to get them but i think they said you need the Win2000 service pack and then useing the specific files off it... good luck.......
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I'm running Windows 2000. Maybe I need to run the service pack again? -
On 2001-10-13 23:29:19, tater1969 wrote:
let me guess,do you have an ati video card?
Yes. -
On 2001-10-13 23:34:08, tater1969 wrote:
check email sent a zip fix to your problem
Thank you so much! -
Now when I select video format I do not get an option where I can select 480x480. When I try to select this in custom format, it says it is unsupported. I am using the latest version of Virtuadub.
I do not see this window when I select Video/Format. I see something else that says stream settings.
<font size=-1>[ This Message was edited by: Alvis on 2001-10-14 08:55:06 ]</font>
<font size=-1>[ This Message was edited by: Alvis on 2001-10-14 08:55:56 ]</font>
<font size=-1>[ This Message was edited by: Alvis on 2001-10-14 08:56:43 ]</font>
Windows 7, Virtual Dub (any Version), BlackMagic Intensity Pro = No Capture
By Digital-Overload in forum Capturing and VCRReplies: 2Last Post: 22nd May 2011, 11:57 -
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 22:31 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36
