I think it makes a chapter every five minutes. Is there anyway to either adjust the time or even disable this function?
I did read manual and onlything that I found was "Automatic every 5 minutes". Maybe somebody who has it can confirm.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
About the only thing you can control is making a whole new "program" by hitting the STOP button during your recording session, which will indeed "end" the program you were recording, and then the next recording you make by hitting the RECORD button will have a chapter point there, and it'll show up as an item in the DVD's main menu.Originally Posted by Bob W
Otherwise, it's a chapter point every 5 minutes, automatically.
This is yet again another area where the hard drive recorders give you extra capabilities -- on the DMR-E80H, you can set "Markers' wherever you want in your programs on your hard drive, and if you use the HIGH SPEED DUBBING to record over to DVD-R, then you will indeed have those "custom" chapter points in your finalized DVD-R.
thoots
Correct Project and Sequence Settings for footage from Panasonic TM300?
By Bloodredthorn in forum EditingReplies: 0Last Post: 20th Jan 2012, 13:34 -
Panasonic AG-1980 - what settings for capturing?
By justin81 in forum RestorationReplies: 1Last Post: 7th Oct 2010, 18:07 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 14:09 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 13:34 -
Automatic DVD Chapter Point Insertion
By cw4u in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2007, 01:43
