my problem.
i'm trying to export a .mpg file in quicktime to a quicktime movie file
i have panther.
export: movie to quicktime movie
use: DSL/Cable - High (or any other choice)
when i export i have no audio. and when i check the options sound isn't checked and is greyed out.
if i try to change the video compression i still can't export with audio for qt movie.
i have checked on two of my computers running panther and both seem to be plaqued by this problem.
i used to be able to export them with audio. I've checked many files i've done over the past month and have found that there is a inconsistancy as to which files have audio and those that didn't.
the ones that do have audio won't export now with audio.
hope all this makes sense. any ideas would be great.
Check chapter "How can I convert MPEG back to DV" in:
http://www.sjoki.uta.fi/~shmhav/SVCD_on_a_Macintosh.txt
QuickTime Player doesn't export the audio in MPEG files so you have to do it manually.
How to convert to .mpg without failing?
By Grahamf in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2011, 18:36 -
need to convert mpg to avchd
By mrgreaper in forum Video ConversionReplies: 5Last Post: 14th Aug 2009, 09:49 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47 -
convert .mov to .mpg
By chalutz in forum MacReplies: 7Last Post: 11th May 2007, 09:51
