i have a problem with my LVD-2002, it doesn't play movies that were ripped to 2 cds. It only plays movies that were ripped to a single cd of ~700mb.
i can joint the 2 cds but can someone please tell me how to make this smaller. i know this will result a lesser quality but that's ok.
thankyou
I very much doubt that the problem is whether the movie is split over two discs, or one.
I expect it's an issue with the codecs used.
What does gSpot (or avi Codec) say about your DivX files?
VirtualDub is probably the best tool for re-encoding your files with the best codec for your player. Use it in conjunction with a good bitrate calculator to get the filesizes you want.
There are guides about doing this - see the link on the left.
cheers,
mcdruid.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Sage wisemen, I cannot post a new "DVD hack" so I guess I put it
By GreenCentaur in forum Newbie / General discussionsReplies: 2Last Post: 10th Nov 2009, 07:46 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
