Ok I asked this question before but got no reply....I have a computer pentium 3 733mgz windows 98 (2nd edition) but could be upgradd to xp if necessary. 18 gig. 256 memory ram.
I want to buy this nec dvd +/-rw because I saw it on this site at 96$ only!
Will my computer support dvd shrink for instance and manage to do a good job at burning dvd?
Some one told me yeah another froend told my no way it would take days..... Anyone??? I want to buy for x-mas....help!
And do you know if this nec dvd writerdoes a good job (at taht price it fits my budget!~)
Thanks in advance!
I see no reason why it won't.
My specs are not all that different.
A larger harddrive is recommended, though you could get by.....just.
If 98se supports the burner i see no reason to use XP. It will only 'steal' an extra GB or more of your small harddrive.
NTFS is not necessary for DVD rips since the *.VOB's are only 1Gb in size.
amd 1.2 sys with win98se here useing nec 1300a and dvd shrink no problem.
Multiregion code for Bose Lifestyle 18 series III
By pgoschebart in forum DVD & Blu-ray PlayersReplies: 7Last Post: 16th Feb 2022, 07:24 -
Capturing from a Motorola DCT6416 III
By mlong30 in forum Capturing and VCRReplies: 17Last Post: 27th Apr 2009, 21:34 -
cannot transcode Pirates Caribbean III World End
By ricksmitty in forum DVD RippingReplies: 1Last Post: 8th Jan 2008, 16:03 -
Anyone have manual for for Vidicraft Detailer III?
By BrainStorm69 in forum RestorationReplies: 13Last Post: 9th Dec 2007, 12:05
