Do I need to do anything other than burn the .iso file I have on a CD?
Wht do you mean by Bootable?
Do you mean copy of floppy boot disk on CD, maybe a copy of your Install disk with the boot disk on it?
Or are you looking for a Linux distro that is bootable, SuSe or omething.?
In either case, you hve to set the BIOS boot order for CD-Floppy-HD1 or 0, depending on the machine I think. Most call it HD0, but never saw BIOS for every machine, soooo.
Ifyou have an ISO, you have to go into your burning app and select "Burn from image". File>Burn Image, find the file, click it, and be done.
Cheers,
George -
If that don't work, use nero to make your CD a Bootable CD. You will need a boot floppy to copy the boot files from.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I believe he means a CD that executes its files the moment you insert. For example, a VCD that play it video by simply inserting it in the CD-ROM.
Hello. -
Ah, in that csse, ifyou ue Nero, do not choose make menu, or whatever the comand is.
I did that, took 'em to work, easy night, the f'in things stuck on "Created by Nero". Never gain.
BTW, without that, they strated instantly. -
That's exactly what I was looking for.Originally Posted by Tommyknocker
@gmatov: I used Nero also and it worked great. -
fm,
Yeah, but this was the Koss player, had to do the pushbutton hack on it to even play VCD/SVCD.
Trying to make bootable CDs / DVDs with ImgBurn
By Seeker47 in forum ComputerReplies: 2Last Post: 24th Apr 2011, 21:04 -
dvd burning error when make a bootable dvd image
By junian116 in forum Authoring (DVD)Replies: 1Last Post: 5th Apr 2011, 04:58 -
How to make a floppy imge from the bootable section of a CD
By nerys in forum ComputerReplies: 5Last Post: 20th Feb 2011, 14:38 -
how to make windows 7 dvd bootable
By mysts in forum ComputerReplies: 8Last Post: 16th Jul 2009, 22:43 -
Windows 98 Bootable CD
By wulf109 in forum ComputerReplies: 12Last Post: 6th May 2009, 10:09
