I encoded an .mpg with TMPGenc coming from an XviD .avi and the audio track (a .wav) that i ripped using VirtualDub. I used TMPGenc's DVD authoring software and burning software to make the DVD.
The audio starts out of sync from the very beginning of the movie.
What is a newbie to do?
The newbie should first decide what kind of synch problem is plaguing him, by how much. If, for example, he hears, "Bond, James Bond." and then see Sean Connery move his lips x seconds later, he has audio leading video. He should load the the video into Gold Wave. Add x seconds of silence and save the audio as a wave file.
If he sees Sean Connery move his lips hears "Bond, James Bond." x seconds later, he has video leading audio. He should load the video into Gold Wave and cut x seconds from the beginning of the audio and save it as a wave file.
Either way, he should then use the TMPGEnc main screen, load the original video as input video, and the new wave file as input audio, and press Start. The resultant file should be a video with good audio synch.
That is what a newbie should do.
Hello.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 13:30 -
audio out of sync with video
By leegutcher in forum Newbie / General discussionsReplies: 3Last Post: 30th Jul 2007, 07:10
