I was re-encoding some Divx 4.01 files to mpg1 to make vcds - framserving from Virtualdub to tmpgenc - no problems. Closed Tmpgenc, changed my mind and decide to continue and do a couple more, reopened Tmpgenc, and now it will not recongize the frameserve file. I get the unsupported file error. I didn't change anything before getting the error. I can open the Divx file in Tmpgenc directly, but I need to do some editing first before sending it. I have tried everything listed in the How To, I have re-installed the codecs and the handler for Virtualdub, rebooted after each. No luck. Any ideas ????
<font size=-1>[ This Message was edited by: psycaz on 2001-10-13 22:50:44 ]</font>
additional information: Virtualdub is v1.4.7, tmpgenc are versions 2 and 12i. I even tried on one of the files I had already done - no go. I have tried changing the priority on the vfapi tab for directshow and vfw - pretty much at every possible position, no luck.
<font size=-1>[ This Message was edited by: psycaz on 2001-10-13 22:41:10 ]</font> -
I diabled the Directshow in TMPGEnc and got no probs, if that doesn't work try AVISynth to frameserve
Thnaks for the help. I ended up having to change the fileserver name to somehting short with no spaces and it works fine again...
Export to FLV using virtualdub and frameserve
By itoo73 in forum Video ConversionReplies: 6Last Post: 5th Jan 2013, 22:46 -
How to frameserve from virtualdub to ProCoder2 ?!?!
By simps in forum Video ConversionReplies: 22Last Post: 14th Feb 2010, 12:16 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 06:24 -
Is it possible to frameserve with Virtualdub to MeGui?
By salidarius in forum Video ConversionReplies: 8Last Post: 13th Feb 2008, 05:41 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
