Hi, I've recently run into this weird problem while capturing video with virtualDub:
The audio seems to be muted when I'm in the "capture video" option of vDub, but the resulting file after the vid cap still have a correct video/audio sync.
I have no idea why this is happening... I've been using vDub to capture videos for years and this just all of a sudden started happening. I've checked the volume setting during capture and that's fine... I've tried capturing to mpg using the ATIMMC and that works fine (you can hear audio while you capture)... You can watch an outside video source fine (like ATIMMC TV)...
Audio just seems to mute itself during vDub capture.
I have different versions of vDub installed in my computer and all of them now suffer from the same problem.
This didn't start happening right after I had switched drivers, so the problem isn't a new driver messing me up.
Maybe something happened to my existing driver?
Anyone out there know why something like this would happen?
It's pretty annoying because I usually watch the videos as I capture them, but now it's pointless because there's no audio during capture.
Results 1 to 1 of 1
vdub - bad PCM audio capture after fresh install of huffyuv
By wolfdogg in forum Video ConversionReplies: 1Last Post: 11th May 2011, 00:45 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
Capturing with VDub sometimes doesn't capture audio
By CursedLemon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Feb 2010, 20:50 -
RMVB conversion end up without audio
By alc112 in forum Video ConversionReplies: 22Last Post: 14th Jan 2010, 00:34 -
Loud Static/Audio Clipping at end of Capture
By brandtb in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2007, 21:20
