I have a MPEG file i think im not sure if it is. How do i check it dosent say anything if i go into properties. Well, anyhow i have a file and everything works but the sound is a little of from the movie. When they stop talking you can still hear them talking. Like the audio isnt "in pattern" with the movie. How do i fix that?
Check your file with avicodec and it will tell you what it is. You have an audio-video synchronization problem, the most asked question on this site. If the audio is out by a fixed amount (as opposed to a sync problem that gets worse throughout the movie) then you can extract the audio, add a positive or negative delay and re-multiplex it back into the original file. Sounds easy, it's not. How you go about all that depends on what type of file you have.
sound commentary in movie
By terblo in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2009, 16:34 -
Movie sound Ripper..
By ranchhand in forum AudioReplies: 9Last Post: 1st Jan 2009, 14:06 -
Main Movie has no sound
By Keesfan in forum DVD RippingReplies: 11Last Post: 31st Aug 2007, 23:32 -
no sound on movie
By natty in forum Newbie / General discussionsReplies: 9Last Post: 30th Aug 2007, 05:45 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
