  1. I have a few cds that i had saved using an open session write so i could add and delete later on. A while later i had to dump my hard drive because of a crash and the burner program i had used to write the cd was lost. Now i can not access the cds at all. Is there a way to extract the info by ripping it from the cd? Thanks.
  2. you could try closing the sessions on the disc with your cd-rw software, you may then be able to view the session.
    but other than that, you could try using iso buster
