I was reading some of the conversion guides...they look a bit complicated. I have never done this before, and I was then wondering if Nero 6 can be used for coverting files as well as burning. I have a feeling this is a bit simpler to use.
Anybody know ? What do people on here use for the process of making a dvd-r og svcd film ? Need som experienced help.![]()
How long does the process take from start to finished product![]()
Nero can do the encoding for you in most cases but it doesn't do a very good job of it. the reason for all the guides for other tools is that they give a lot better quality and less problems than Nero.
TMPGEnc plus and CCE are the two top encoders in a good pricerange. Canopus Procoder is also a very good one, but more expensive I believe. I use TMPGEnc myself, and haven't tried CCE yet. I hear CCE is faster at encoding though. If you are doing DVD I'd suggest getting the TMPGEnc Plus & TMPGEnc DVD Author package. both programs are excellent and together they can be bought for $99. there is a trial version of both available.
as for speed there are so many factors that can effect that. how fast your computer is and your system resources along with what options you choose to encode under in the program. I did a set of SVCD from DVD last night and the encoding took about 2.5 hours with TMPGEnc. thats on a PC with a 2.6Ghz P4 and 512MB of RAM with a 7200RPM HD. encoding can go anywhere from around an hour to more than a day depending on your setup.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 21:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
