maybe a question that have been asked before
but i couldn't find it with search
with what software do i do it
and can i play it on my tv directly when capturing?
thanks in advance
sorry Truman, you misunderstand me
i want to now which software
can send from my computer to my camcorder
with a firewire connection
or something else?
(i wanne capture my edited mpg back to dv)
and play it on tv!
..oops, excuse me. I never did that. I imagine, Windows media player and a graphic card with TV out should be all, what you need.
Use MovieDV4.0 from aist (www.aist.com). This program has the function "print to tape", e.g. you can load first the mpeg or avi clip and then "print" it back to the camcorder via firewire.
Cheers
Pat -
what program are you using to transfer from the camcorder to the computer. I think all or at least the majority of them have a "back to tape" option in them. I know that studio dv also has a back to tape. If you want to do it with the firewire. If your card has an out you could also use that connected to the analog inputs on the camcorder, however the quality would suffer.
I bought a enable widget so after editing etc you can enable record through firewire back to your dv camcorder,make sure your dv camera is compatible.This is for uk and european camcorders that dont have the option to record enabled.
Missing audio in mpg files from Sony Camcorder in Final Cut and Quicktime
By Benhermies in forum MacReplies: 3Last Post: 2nd Feb 2011, 23:13 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 11:49 -
VirtualDub can't open my mpg from camcorder
By ssalim in forum Video ConversionReplies: 3Last Post: 2nd Dec 2008, 17:46 -
Capture from DV Camcorder
By quxote in forum Capturing and VCRReplies: 2Last Post: 16th Jun 2008, 23:41 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31
