Hi Major and other readers,
I ripped a dvd into one large VOB file - containing the mpeg2 video, the ac3 audio and one set of subtitles.
I then used the svcd preset to encode the video, while deliberately skipping the subs and setting the audio to 'through only'.
However, after the 'finished' message, it turned out that only HALF the video had been encoded (and looked perfect enough). The total movie had the right length though, because the audio had been handled correctly and fully. It's just that the second half of the video was all black, and the total file size was roughly one half of my estimate.
Any idea what went wrong?
Thanks ahead!
Johan_NLGuest
Johan_NLGuest
Yup, it was over 6 gig in size,
so I assume you're right.
Thanks for replying!
I'm going to try n use mencoder now. Do you know if there will be a difference in quality compared to Quicktime? (and if so: plus or minus?)
Greetings,
Johan
VCD vs Half-D1 vs Low bitrate full-D1
By nharikrishna in forum Authoring (DVD)Replies: 44Last Post: 6th Feb 2011, 23:50 -
512x384 to DVD? Full D1 or Half D1?
By rayden54 in forum Video ConversionReplies: 19Last Post: 9th Sep 2009, 00:44 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
Full D1 menu and half-D1 video in DVDA 4
By itsme1 in forum Authoring (DVD)Replies: 3Last Post: 13th Jul 2007, 11:00 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
