I want to rip from my home made movie that burn from philips recorder,i tried to back up to my hard drive,but get error message,i tried dvdshrink it only rip 99%,than error.Then i tried dvddecrypter no luck get error message.
Need help.
I know they don't work in DVDShrink....but I use DVDDecrypter all of the time for discs from my DVDR985....in IFO and ISO modes...don't use file mode for much of anything.
I tried dvd decrypter in iso mode,still no work,only 99% complet and pop out error message(I/O error) now i am going to try ifo mode.
If they wont work in ISO mode....which is a basic COPY DISC type of function....then I believe there is a setting either in DVDDecrypter OR on your computer that you should be looking for. I'm no expert but...that is MY personal opinion.
You don't have to RIP a copy. Just drag the VIDEO_TS folder onto your HD and burn it like usual. Decrypter and Shrink were designed to rip encrypted DVD's, and yer trying to make them rip an unencrypted copy. However, I've seen posts where Decrypter in ISO mode worked on a copy.
Lastly.....using the copy disc function in yer burning software should work also. -
If you nero copy function to made copy the quality will be worse(i already tried this).
Finally i use clonedvd to made a copy (quality is almost same as original)and can use dvdshrink to compress and made minidvd. -
Ahhh....hooey. Using Nero I've made several copies of backups and they all look identical to the original. It's an ISO image, or on the fly copy, there is no compression or encoding involved. It's just moving data from one disc to another without changing it at all.
philips 3506 dvd recorder help....
By longlip in forum DVD & Blu-ray RecordersReplies: 2Last Post: 28th Nov 2008, 14:01 -
I need a help with my dvd recorder ( Philips dvdr3320v/01)
By febius in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 13:09 -
2 disc movie to RIP and Burn
By naftalim in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2007, 13:44 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50 -
after buring DL+R disc, my burn can't burn -R disc, please help!
By princejoe18 in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Sep 2007, 08:44
