  1. Howdy, I just installed a Pioneer 106 (firmware 1.07) and have Nero 5.5.9.14, which i'm sure can burn DVD's. I wanted to put some files onto a DVD but Nero won't recognise my DVD drive!
    Can anyone help?
    Thanks.
  2. I had a similar problem with my Sony OEM drive. Have a look on Nero's website and see if your drive is supported on that version. If not is there a later version of Nero 5 you can use.
    I ended up going to Nero 6 and it was recognised fine.
    In fact I just checked the site and Nero claims that the Pioneer 106 needs version : 5.5.10.45
    Check it out :
    http://www.nero.com/en/632012038142166.php?manu=Pioneer&lang=en
  3. Thanks for the help. I downloaded the latest version of 5.5 from Nero.com and it works.
    Thank you.
  4. Just the first problem solved in a long line!
    Good Luck
    ----Figured it out yet?
    ----What's that?
    ----Who's the best pilot!
    TOP GUN (1986)
