Hello
I hope that I am posting this in the right area, I have a quick question with regards to the quality of a DVD that I recently burned after capturing footage from my digital camera.
I have been trying to think all night how best to describe what is actually going wrong with the image as the picure is quite good. The best way is to say that it seems to lack definition, as if the images are slightly cloudy perhaps. It is mostly visiable when the images are dark or rather close up.
To capture I used MS Moviemaker to WMV and the saved project as DV-AVI before using TMPGEnc tools to convert to MPEG and then DVD format VOB files.
Any ideas where this would be occuring, could it be capturing in WMV first (I did this as the rendering time for AVI was up to 4 hours) or is it perhaps settings in the TMPGenc tools. Any thoughts would be welcome.
Is this what is refered to as "noise"
Cheers
Try capturing straight to DV instead. I havn't been happy with WMV the little I tested it.
- Capture withvirtual dub. You would need like 18Gigs for 1:30 movie
- Convert it to mpeg2, if you have a template, select VBR 6000 or CBR 6000 or 7000, whichever is greater.
Looks like somewhere in the process, there was some kind of compression or resizing. Try with a small portion of video, on the part where you have problems and see if this works for you. -
DVIO is a freeware program that allows you to capture to DV AVI from FIREWIRE input.
So capture that way. My bet is on the problem being with WMV capture thing.
High Definition Video on SD DVD
By TheLaserdisc in forum Authoring (DVD)Replies: 6Last Post: 19th Apr 2011, 22:42 -
How to burn high definition video to DVD?
By local2 in forum Video ConversionReplies: 1Last Post: 13th Dec 2009, 14:53 -
By local2 in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2009, 14:52 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00 -
High Definition video converting to DVD
By Turvy in forum Authoring (DVD)Replies: 5Last Post: 14th Jan 2008, 09:50
