I bought 3 of the 25-packs of TDk 2x DVD-R TDKG02 from Best Buy this week.
Odd thing is about 1-2 discs per pack fail at the lead-in. The discs bring up no info in DVDINFO and are basically a coaster before the burner even gets it.
The $30+tax is still a good price for 23-pack in stores I guess. But I was sold 25, would be nice to have them.
Had one coaster from Memorex DVD+R 4x RICOHJPN too. Another burner, not sure what caused it.
Very odd these media are. Too pricey for duds.
Anybody else seeing this kind of thing? Duds right away, NOT burner-made or balance-related (normal reason for coasters, whereas end of disc won't play or the disc pauses and freezes in player).
Results 1 to 9 of 9
I believe that i had the same TDK's and failed to bring up on dvdinfo, i forget how it was fixed. But they work great and i just picked up 50 from Bestbuy. So yeah TDK are good to buy, i doubt the Best but a good buy.
"A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press -
I've burned a whole lot of TDK 2x -Rs without issue in the past. No comment on the current TDKs as I havne't picked any up yet.
100 Disk TDK 4x +R spindle, all burned fine.
200 (25 Disk) Memorex Spindle 4x +R, all burned fine.
0 Coasters, 0 Bad Burns
2 different drives (Nec ND1100a and Aopen DRW4410)
All my Memorex were Amazon.com 25 for $29.99 disks. My TDK were Ebay.com auction. Just ordered 150 more Memorex (6-25 disk spindles for $171 delivered)
All Ricoh.
All Good Stuff!
I had 5 of 25 memorex dvd-r's fail.Bestbuy said i would have to contact memorex,i hate bestbuy.
I don't see anything wrong with that...as Best Buy will have to send them back to the vendor. I've never seen them sell media as an "OPEN BOX" item...so I doubt they resell it. This is kind of like the same thing with the Sony burners....when you open the box there was sticker inside that said if you have a defect with the burner DO NOT return it to the store you purchased it from, instead send it to Sony for repair.
So if you purchase a burner and got a defective..you'd have to send that defective burner to SONY in the hopes they could repair it and send you back a "REPAIRED" defective burner...in the meantime..you'd pay the shipping to SONY while having to wait for it to come back....that sounds fair right? LMAO....I actually did get a defective burner..had a defective laser....I took it back to Best Buy and got my money back the SAME HOUR...not the same day..but within' the SAME HOUR. -
Out of 50 TDK 2x DVD-R TDKG02, 4 coasters, 19 unused, 27 flawless burns. The 4 are DOA. Cannot go past lead in.
Out of 25 Memerox DVD+R 4x RICOHJPN, 1 coaster, 4 flawless, 20 left.
The problem on the + discs seems to mostly be the burner. Insofar as you cannot switch to + and - at will. If I want to use all + media, then it's fine. Or is all - media, then fine. But to switch, I must first reboot. The TDK are just DOA.
Probably gonna run back to RITEK again. Sigh. So much for the local "sales" on "good" media. Not a sale after coasters factored into price.Want my help? Ask here! (not via PM!)
havent had one coaster from all the memorex +R 4X ive used (about 100 disks)
using an optorite burnerNewbie Maximus -
Burning Memorex, I had not problems but the discs won't play in my Playstation or my parents DVD player. Plays on my computer and DVD player fine. So I have only had compatibility issues.
_
Garbage In, Garbage Out: An intro to restoring
By lordsmurf in forum RestorationReplies: 8Last Post: 15th Dec 2018, 10:16 -
ridata dvdrs are the absolute worst garbage you can buy
By octeuron in forum MediaReplies: 49Last Post: 20th Jul 2010, 16:07 -
auto cropping of black and garbage pixels
By 4evrplan in forum EditingReplies: 4Last Post: 12th Feb 2008, 16:32 -
What should I do with these TDK's
By Waltj in forum MediaReplies: 6Last Post: 2nd Jun 2007, 23:27 -
Remove noise garbage from bottom of video.
By mlong30 in forum EditingReplies: 24Last Post: 10th May 2007, 21:41
