    Dec 2002
    Atlanta, Georgia
    Im no sure if im allowed to ask this, or if this is the right forum, but ill give it a shot. I was wondering if there were any sites were you could find covers, or labels to print and put on your backed up dvdr. Ive got teh special paper with the pre cut-outs, and the software to print it. I just need a place to get it. Ive tried scanning a dvd before, but that doesnt look right, and i can never get it to fit and etc.
    So, just wondering if someone could pass on a site, or something in that direction.
    Thinks
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Please do a forum search, there are a ton of topics on this. Some in the last few days.
    Dec 2002
    Atlanta, Georgia
    i did do a forum search, and it came up with so many results, that it wouldnt show them to me. So I though i would post. Sorry.
  4. Originally Posted by iownju
    What software do you use for printing out ?
    Try a google search for cover software or use nero cover designer which is with nero .....
    All good software should have the option to resize what you are printing out or even templates which are the correct size so all you do is drag your scans to the correct size.
    Not bothered by small problems...
    Spend a night alone with a mosquito
