I'm putting together several clips and titles onto the timeline of my movie and for some reason the colored bar directly above the numbers on the timeline is blue in some places and red in others.
Here's a pic of what I mean: http://www.personal.psu.edu/sms540/Pic4.JPG
The colored bar is blue over the first title and over the movie clip, but it is red over the second title. This second title is giving me problems so I'd like to know what the different colors of this bar means and how I can change it.
Thanks in advance!
Tim Kaiser
Simple. It means that part of your movie is not rendered. You may have noticed that when your preview gets to that part (red part), the movie gets choppy Go to Timeline>Render Work Area and the preview should be ok. When you export the movie, it will be fine (reguardless if you Render the work area or not, exporting will automatically render it).
Hope this helps!
Problems with Adobe Premier Elements
By jeffprice74 in forum EditingReplies: 4Last Post: 21st Jun 2008, 10:24 -
Adobe Premier Elements 4
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 22:01 -
Adobe premier cs3
By m baqar in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 21:55 -
problem with my adobe premier 7.0
By pondleaping in forum EditingReplies: 4Last Post: 13th May 2007, 10:29 -
Adobe Premier Pro 2 - Picture effect question
By flipzoso in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 21:54
