hi,
i cant seem to get 2 movies on one dvdr, do i have to select a folder with bin files in or mpegs.
ive followed the word97 walkthru about seperate vts folders, but when i did two films, a 3 disc one and a two disc one, the second movie wouldnt play when u selected its name on the menu.
a step by step walkthru would be appreciatted.
a little confused at the moment.
cheers....
tigerxGuest
I got a few questions.
1. did you play it on your computer with a dvd-player like windvd or powerdvd? If so did you have the same problem? If not could you try?
2. We need some information about both movies. NTSC or PAL? VCD or SVCD?
3. Can you select the movie track with your remote without using the menu of the dvd? Does it play then?
4. Can you skip to the second movie when you start with playing the first movie?Greatings,
Yf
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 20:53 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14
