I have a kvcd file 774mb when i use tmpenc i end up with a 995mb file.....making it larger rather then smaller..any suggestions?
if you can help i posted more info in another category here:
https://www.videohelp.com/forum/viewtopic.php?t=84759&postdays=0&postorder=asc&start=400
Thanks,
Yes thank you I know that. The file size is 774 MB the movie is 1HR:39MIN:47SEC in length. I actually tried overburning using nero by setting the default 82min to 100 which im guessing is not a good idea...then nero froze and my drive started to show a red light so that didn't work. i'm using tempenc because i saw a guide conversation and it said something about using it to make the file smaller by making a one disk vcd template then you end up with a desired file size..etc..
does this make any sense?
i also have a big .mov file that i want to turn to vcd but not sure where to start.
thanks, -
Ummm, no.
No overburning required.
Use the nero template for VCD. Drag in the MPEG, and turn of 'complient', since it's non-standard. You can drop an 800 MB VCD into Nero and it will burn on a 700 MB CDR.
You see it's like this: A 700 MB data CDR has 800 MB of space on it. The difference is for error correction and 'formatting'. VCD/SVCD doesn't have any error correction, so you can stuff a little more in there.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
found my problem..the guide i was going by said to make your own template... i'm now trying the vcd template..that should fix thingsOriginally Posted by Gazorgan
thanks,
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 16:37 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
MPG to KVCD HELP
By G33333 in forum Video ConversionReplies: 12Last Post: 25th Dec 2007, 07:00 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 16:31 -
KVCD to DVD
By buttzilla in forum Video ConversionReplies: 2Last Post: 6th May 2007, 09:01
