I have about 30 VCD disk's from old cartoon shows purchaced in Ebay ,I would like to put them on DVD disks .How do you do it ???? I am familiar with cloneDVD and other burning software, So am not a total thumbs newbie
hope some one can help
SVCD2DVDMPG and the authoring and burning software of your choice.
(Does not work with 23.976fps NTSCfilm VCD's, they must be re-encoded) -
I myself have been doing this same thing, an really there a # of diff ways,,
the way Ive been doing it is, like so, [this is with mpeg ofcourse]
''rip the files from the vcd to your PC's hard drive''
theres way to do it with just normal win xp,
but ive been using isobuster.
you'll get a file thats like 'AVQ101' or something like that,
then just Rclick, rename,,
an name it whatever u want just be sure to put .mpeg or .mpg
on the end of it,
like // cartoonshow1.mpg
then just use your dvd writing software of your choice , nero,MYdvd, whatever!!
Most have just a drag click & burn
I know its alot more convient to have like 4 or 5 shows on 1 dvd,
instaed od 5 shows on 5 diff, vcd disks,
Now Im still new to this myself, an like i said there are a few different ways, just find whats good for u,
I myself have been doind the above,,Bare with me please,,brain cellz not functioning at normal capacity!! -
Will these transfer based on size? For example, can I get 6 full 80 Min. vcds(approx. 4.2 GB) on 1 4.7GB DVD-R?
This is bad.Originally Posted by Bryan_B26Want my help? Ask here! (not via PM!)
DVD Lab Runtime error c++ compile.aux?
By dcook in forum Authoring (DVD)Replies: 10Last Post: 29th Aug 2010, 22:46 -
Using Magix Photo Story CD/DVD 8 to compile photos
By Surber in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2010, 20:08 -
Compile VCD movies plus subtitle into one DVD
By GeekyChocolate in forum Newbie / General discussionsReplies: 5Last Post: 26th Feb 2009, 08:14 -
Noob here, Compile Dvd problem!
By dbgt in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 19:08 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
