Results 1 to 9 of 9
  1. well im getting tired of my toshiba Toshiba - SD-R5002
    so im lookin at these 2
    LG Electronics GSA-4040B
    nec 1300a
    what one is better of the two and is there any other burner you would you suggest instead .
  2. Member Treebeard's Avatar
    Aug 2002
    both are similar, lg might support more cheap media out of the box, but why mess with cheap media in the first place.
    i picked up my nec1300 for $95, now just waiting to get the discs.
  3. what media would you use im pissed i just got 100 princo 1x and they where suppose to burn on my toshiba at 2x but with nero6 they are only burning at 1x with the latest firmware
    Jan 2002
    Australia
    I'm using a LG 4040B, 60 odd burns at 4X on DVD-R Princo's and no coasters!, burnt TDK and Ricoh DVD+RW, DVD-R and DVD+R no problems.
    ???100 princo 1x and they where suppose to burn on my toshiba at 2x??
    I wonder why????????????????
  5. I have the NEC ND1300A and it burns everything even princo's. Im thinking about getting another since the price keeps dropping.
  6. well i got the lg i got a really good deal on it $102 bux thanks alot for all your input
  7. Do you want to sell your Toshiba SD-r5002?
    Not worth alot now since 4x dual format drives are so cheap though. Might be better to keep as a spare. But if you want to sell it cheap PM me, I might take it for the kids system.
    I have one, I never heard of 1X princos supposed to burn at 2X on it though! I burn leda/princo at 1x, ritek G03 and G04 at 2x.
    Nero is buggy! I just burned a ritek G03 with Nero the other day, Nero said burning at 2x, final summary stated succesfull burn at 2x also. The truth though is it took 1hr to burn and that is 1x, so Nero lied!!!
    Same disks do burn at 2x (about 30 minutes) using Tmpgenc DVD author built in burner. Every Ritek burns at 2x with that program, so it's a Nero problem!
    As for burning a princo 1x disk at 2x, never did that!
    If your using Nero with your new drive and don't get full speed burns, try a different program!
    overloaded_ide
    Spambot FOOD
    Anti-Spam
    Oct 2003
    NEC drives are somewhat instable. My drive for instance, doesnt burn Princo's at 4x, coaster's every single one. But at 2x it works fine. My friends drive wrote 4x princos with no problems, for a while. now it also craps up. strange.
  9. Member MysticE's Avatar
    Nov 2003
    The LG got a pretty bad rap here:
    http://www.cdfreaks.com/article/126/1
