If you had the choice would you?
A) Upgrade current computer to:
P4 2.6C GHz 800MHz FSB, 512K Cache, Hyper Threading Technology
512MB DDR PC-3200 (400MHz Memory)
Video Capture Card...A good one, but not over like $200.00
B) A DVD Recorder
Just want your opinions...If you choose "A" also tell me which capture card you would buy.
Thanks!
For (A), I wouldn't buy a capture card - I'd buy an analog-DV converter, like the Canopus ADVC-100 (~$250) or an ADS Pyro A/V Link (~$150, what I have). I've tried various cards and MPEG-2/USB 2.0 solutions, and they are inferior in easy-of-use and quality to the analog-DV encoders.
These devices allow you to connect any analog source and output a DV stream to your PC's 1394 port. All the NLE's on the market accept DV input, so you can use whatever NLE you like. They also lock the A/V stream, so you never get desynchronization. And dropped frames is rarely a problem, certainly not with the system you describe. -
The ADVC100 is actually what i am kind of leaning towards. Alot of people around here seem to think it is the greatest thing since sliced bread. LOLFor (A), I wouldn't buy a capture card - I'd buy an analog-DV converter, like the Canopus ADVC-100 (~$250) or an ADS Pyro A/V Link (~$150, what I have). I've tried various cards and MPEG-2/USB 2.0 solutions, and they are inferior in easy-of-use and quality to the analog-DV encoders.
Yep, the ADVC-100 is fine.
But - lookin at your current equipment, you may want to look at an additional/bigger HDD. Capture rate for DV will be around 13 gig/hr with the 100.
Dilema ? Problem when converting video with audio track
By doward in forum ffmpegX general discussionReplies: 5Last Post: 1st Dec 2010, 14:32 -
Realtime Encoding dilema
By OldMedia in forum Capturing and VCRReplies: 0Last Post: 8th Oct 2010, 13:31 -
DVD Burning Dilema
By aruba92 in forum Capturing and VCRReplies: 7Last Post: 25th Jan 2009, 13:44 -
My Dilema - Which Recorder and how to set it up?
By thomamon in forum DVD & Blu-ray RecordersReplies: 13Last Post: 4th Dec 2008, 12:24 -
Dilema: Hauppauge 99016 or WINTV-PVR-USB2?
By WetLight in forum Capturing and VCRReplies: 0Last Post: 11th Jun 2007, 05:42
