hello, I used tmpegenc to ecode an avi that I have in 25 fps to 23.976 fps in order to burn a DVD. However, when I encoded, I forgot to set the encoder to 23.976 (29.976 internal) in order to "flag" such that it would work properly. Now, I'm trying to burn/author and I need to "re-flag" the m2v file such that it will author properly. Is there an easy way to do this or do I have to re-encode again?
thanks in advance
NK
Use pulldown.exe. You may want to get the gui also for easier use. If you just use its default settings it will all the pulldown flags.
It only takes 5 mins or so.
DVDstyler - LPCM Audio incorrectly flagged as AC-3
By trellis2 in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2012, 01:17 -
BD incorrectly flagged as interlaced - how do I set to progressive?
By DragonQ in forum Blu-ray RippingReplies: 3Last Post: 18th Dec 2011, 08:29 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 18:55 -
How to detect a VIDEO_TS folder is pre-flagged with CSS
By newcyberianDVD in forum Authoring (DVD)Replies: 0Last Post: 28th Feb 2008, 15:54 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 11:29
