Just got the above dual fromat writer, but when I put a -R to write to I get the message, "writing to DVD not succesful. Write DVD LL5"
The frimware is 1.08 and +R/RW work fine.
Using 4.7gb -R disk which seems unbranded but has the initials P.A.G. on it
The NEC is picky about -R media, especially with the official firmware. You could try Herrie's hacked firmware, or just buy high quality disks when you want to use -R disks. Look for made in Japan on the side of the case if you are buying locally, or buy online and get Ritek.
Here is Herrie's site: http://www.herrie.org/
Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?
By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 12:24 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 07:16 -
NEC TV to Pioneer DVD not working well
By Prasanna in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2008, 05:19 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13
