I am trying to create a slideshow using this application. First I import the images into this application and then i select them all to drop and drag them into a scene. So a scene can have many pictures. Then you do another one and another one. Basically each scene contains pictures of my baby for the first month and then the second month and so on.
I can only put one transition between the scenes but not between the pictures within a scene. Can anyone help me with this? Thanks!
tvandang
You mentioned how you wanted a transition from picture to picture so let's say you have a scene with a bunch of pictures of your baby at one month. You could put each individual picture from month one in a separate box and put a transition between each picture instead of dragging all the pictures into one box. You could then output that whole scene to a file, go back to WinDVD creator and put the first month in the first box, add a transistion, and follow the same procedure with month two.
I use the storyboard method when I speak of "boxes" and find it to be extremely easy to use. I like to compile clips of scenes from my favorite movies and like your pictures, I cut and edit a movie scene into two storyboard boxes and then output it to a file format.
Please let me know if this helps or if you're confused.
Bright Knight
Re: getting interactive chapter marks windvd creator 2
By tomcat862 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2008, 14:38 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 07:39 -
Cannot get audio in Windvd creator 3 under windows vista.
By syllinx in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2007, 23:43 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 18:15
