Yeah man, you're giving those of us with two brain cells a bad name!Originally Posted by Will Hay![]()
Closed Thread
Results 301 to 330 of 350
Hey Rob
What do yo think of the latest picture (considering it was taken via seventeen miles of cable, through four floors, a slate roof, the neighbour's kitty door and my mother-in-laws sock drawer)?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Originally Posted by rhegedus
Nope
Yeah, sure, but like I say, remember the signal matey, it's gonna have an effect.
To be honest, if that's the worst it's gonna be (before I hook the satellite directly - after the hols) then I'm dead happy, I can live with that quality.
Actually, now I think about it I may have reduced that pic in size so I'll do a couple more and e-mail to you tonight.
What you want them for Rob, and what is your opinion on why they look so dark on my monitor yet good on my TV?
You have SO many posts because you insist on posting like 3 or 4 times in a row and yes I have noticed it in other threads AS WELL AS this one!Originally Posted by Will Hay
Merry Christmas
Will Hay claimed: "Please folks, don't be under any illusion - the quality I'm getting from the ADVC-100 at the present time (without any colour adjustment in TMPGEnc) is unacceptable to me. "
Since the screen captures are essentially indistinguishable from one another, the obvious answer is self-delusion. This happens all the time, particularly in high-end audio. Objective double-blind tests have shown no audible difference twixt $10,000-a-foot mercury-filled super-high-end rubber audio cables and Radio Shack $3.95 audio cables, yet self-deluded people continue to convince themselves that ultra-high-end mega-expensive linear crystal oxide free copper (and other types of) high end audio cables somehow magically "improve the sound."
The acid test here is the objective double-blind experimental test. Since the screen captures look essentially indistinguishable for either the ADVC-100 or the ATI on my computer monitor, here is what you should try to elimiante the self-delusion factor (also known as "the placebo effect"):
[1] Capture identical segments of video with the ADVC-100 and the ATi card. Encode 'em with identical software (TMPG, for example) and rename the MPG files.
[2] Now write a short batch file to randomly rename the MPG files and write an identifier file telling which file was renamed to what. For instance, this short batch file might rename FILE1.MPG to FILE7.MPG and then write an entry in a .TXT file that says "FILE1.MPG was renamed FILE7.MPG."
[3] Take the renamed MPG files and burn 'em to DVD. Do not look at the identifier TXT file that tells you which original file was renamed to what.
[4] Play the DVD for a group of people and ask them to tell whether the video clip was captured with the AVCD-100 or the ATI card.
[5] Now read the identifier file and compare the viewers' responses with a normal distribution. You will need to do some statistical work, particularly with Students T-distribution to make sure that intrasubject variance is not => intersubject variance. Unless you have a very large sample group, you should avoid exte4nsive ANOVA because the variance is sensitive to the exact shape of the distribution, and if it's not very close to a normal distribution this could skew your results.
For more detail on using objective double-blind experiments to eliminate "the placebo effect" in subjective claims like these, see the chapter "Baloney Detection Kit" in Carl Sagan's excellent book "The Demon-Haunted World."
WHAT AN EXCELLENT THREAD...and to think the reason I read it was because there was a link to it in another post somewhat suggesting that the the "black box" was not very good.
After reading this, I am almost definitely going to buy it!
Rob or Will, can you tell me the programs you use to capture the footage from the ADVC and then to encode to mpeg2 (and what codecs) and then to create DVDs.
and also the settings you use throughout.
(Rob, if you could answer this too, it would be excellent since your caps were superb on screen too)
This would be a great help.
However, something never mentioned in this whole post (until the statistical nonsence) was sound!
What is the ADVCs sound like? Is it an improvement to the "RCA to 3.5mm jack into sound card" method that is used with TV capture cards?
Also, I do not understand how the ADVC - through firewire or is that just for video (you can tell I am a newb.)
P.S. Will, do you still get colour saturation on the monitor?
It doesn't really matter what you capture with, Movie Maker in XP will be as good as anything else. A friend of mine has Vegas Video and I've been very impressed with it but don't want to spend that much - I'll wait for an e-bay auction.
Encoding is done with TMPGEnc - outstanding results. If you're capturing VHS or TV, encode at 352x576 (PAL) or 352x480 (NTSC) using a bit rate of between 3000 and 4000 - maybe less if you do 2-pass VBR.
Authoring is done with TMPGEncDVDAuthor - I don't go in for fancy menus (I also make dvds for my dad who is still in the play/pause/stop world of vcr) so I just use the no menu facility.
Sound is as good as the pictures.Regards,
Rob
I have just discovered this: http://www.smartdv.co.uk/product.php/30/12/
I have a supported Digital 8 camcorder.
I was wondering, one advatages will I receive with the ACDV 100?
Variable Bit Rate as opposed to Constant Bit Rate - see the glossaryi) "using a bit rate of between 3000 and 4000 - maybe less if you do 2-pass VBR." - what do you mean by VBR?
Noii) Is there any frame loss or out of sync sound and video?
DV capture is at 720x576 (PAL) or 720x480 (NTSC) but since the source, usually VHS or TV, is only half of this, you can encode at half resolution i.e. half D1 x D2 = 352x576 (PAL) or 352x480 (NTSC). It's not 360x whatever since 360 isn't a valid DVD dimension, but 352 is.iii) What was the 1/2 d1 thingy I read aboutRegards,
Rob
You can only judge a man by his ability to admit when he's wrong.
And right now I must be king of the world
Will
EDIT: Admit I was wrong/confused/niave about my setup, not about the pig
I use Pinnacle Studio 8 to 'capture', add transitions, edit and then save as an avi using the same settings I used to capture.Originally Posted by TheGame7
That way I don't re-render my original footage and lose quality.
I then import into TMPGEnc Plus and encode to mpeg2 352 x 576 at 4000CBR (for broadcast and VHS footage, I use 720 x 576 at 8000CBR for home video shot with m MiniDV handycam).
Ithen author with Ulead Movie Fcatory 2.0.
Like Rob, sometimes with menus, sometimes without.
Yes, it's all via firewire, sound and video.Originally Posted by TheGame7
It's not really capture.
The ADVC-100 does all the hard workd and then effectively just tranfers the signal, sound and all, to our computer via firewire.
Yes, but I don't the colours on the final output file at all.Originally Posted by TheGame7
I did some testing with different settings and the original was by far the best.
I'm now in the process of running a firewire cable from my satellite box/VCR downstairs, like Rob, to improve my 'captures'.
I was thinking of moving the PC to the dining room but that was too drastic, I think I'll just drill a small hole in the corner of the ceiling, behing the living roon curtains and hope my wife doesn't see it
Will
Hey will, I've been following your thread quietly for the past 9 pages and I think you might have the same problem as me? maybe not, but here it goes:
If I play my captured DV2 video on powerdvd from the canopus, it looks too dark and too red. However, if I open the file twice, the second instance of that file appears to show correctly.
So what I do on my pc is: first open the video file with media player and minimize the file, then I open the file again with powerDVD(or media player), and it shows the way it should (correct brightness and color).
SInce then I have swithced to nVidea's movie player which isn't perfect either, but shows better color. So my problem (same symptoms as you?)ended up being PowerDVD's codecs.
Hi,
Perhaps the skybox is being to generous in the amount of saturation its applying to the signal after its converted it. Can you alter colour levels from the onscreen menu. Also Sky boxes can output macrovision perhaps this is effecting things.
Maplin do a RGB to composite/svhs converter if you switched the box into say rgb output mode you could uses this to generate your signals and possibly control the levels.
I've seen oversaturated signals though a TV aerial which was receiving to much signal and overloading the components. After an attenuator was fitted it was fine.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
Ati All In Wonder HD and PS3 screenshots and capture HD video.. help needed
By C.P in forum Capturing and VCRReplies: 6Last Post: 30th Mar 2010, 17:46 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 01:23 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 08:15
oops, pistol-whipped
