Tried looking for previous posts on this one but could not come up with a solution. I wanted to capture analog directly into MPEG so I don't have to render an AVI with TMPGenc. I tried rendering twice and it took about 6 hours to render 2 hours of AVI video.
The PROBLEM: Unable to set Ulead Movie Factory to Capture format of MPEG or AVI. Friend installed ULead on my laptop and wanted try it out)
Wanted to capture 8mm video from a Sharp VL-A111U camcorder passed through a VCR (because the Sharp has mono output and VCR splits mono into left and right audio) then through a ADVC 100 connected to a HP laptop (2.66 GHz, 512 RAM).
The ERROR: So I tried capturing with Capture format set to either DVD or DV and the following is the error message.
" V129: Invalid video aspect ratio/display horizontal size(720) combination for DVD, display sized should be 540
Can not set MPEG prarmeters error
Capture failed.
The created file is corrupt and unusable.
It will be automatically deleted. "
May I ask if someone could give some ideas or direction.
Thanks in advance
Results 1 to 1 of 1
MTS unable to play in WMP11/unable to edit in Movie Maker
By xxx4reggie in forum Newbie / General discussionsReplies: 6Last Post: 23rd Nov 2011, 00:04 -
Video Capture Issue - MPEG format
By SD123 in forum Capturing and VCRReplies: 18Last Post: 11th Feb 2011, 15:48 -
Which DV codec does capture software select?
By hollowman in forum Capturing and VCRReplies: 21Last Post: 24th Aug 2008, 14:53 -
Camstudio -> Unable to select audio encoding in Mp3 @44.1 kHz
By ontherocks in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2008, 17:44 -
Ulead Movie Factory Issue / Mpeg files
By DVDdummy in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2007, 23:57
