I am trying to put 83 minutes of stuff onto a VCD (which, of course requires a slightly lower bitrate than the standard parameters), but I can't get TMPG to encode at the bitrate I need in order to do so. I can change the video and audio bitrate settings, but the resulting file size is unchanged from what it would be if encoded with the standard VCD settings. For example, I have a 10 second clip I have been encoding with various settings, to try to figure this out. If the "Stream type" setting on the system tab is set to "MPEG-1 Video-CD" or "MPEG-1 Video-CD (non-stnadard)", the file size is always about 1700KB, regardless of the actual video and audio bitrate settings. If I change the stream type setting to "MPEG-1 System", then the file size does vary with the video and audio bitrate settings.
The problem is that I need a slightly lower bitrate, but I can't get it in a file that can be used to create a VCD. I admit that I am not very experienced at this sort of thing, so I am hoping that someone out there can tell me what I am doing wrong. Thanks in advance.
By the way, I am using TMPGEnc version 2.59.
Results 1 to 1 of 1
VCD vs Half-D1 vs Low bitrate full-D1
By nharikrishna in forum Authoring (DVD)Replies: 44Last Post: 6th Feb 2011, 22:50 -
Changing AC-3 Bitrate (Problems with AC3gain)
By dabas in forum AudioReplies: 3Last Post: 30th Jan 2010, 14:55 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 01:24 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
