It used to be there when I had divx codec 5.1 installed. I uninstalled it and reinstalled Dr. Divx (5.11) and it no longer shows as an option when I choose Compression. How do I get VirtualDub to realize the encoding codecs are there ?
You need to install a DivX codec. If VDUB doesn't see it, then there's no encoding codec there. Some DivX codecs won't work if you remove the spyware.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks - I did find this which fixed it:
http://forum.doom9.org/showthread.php?s=&threadid=24305
Does the interleaving option in VirtualDub 1.9.11 handle 5.1 sound?
By WebMaximus in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2012, 06:43 -
different compression virtualdub
By chewie8008 in forum EditingReplies: 14Last Post: 8th Aug 2009, 12:45 -
Virtualdub compression
By quxote in forum Newbie / General discussionsReplies: 25Last Post: 26th Jul 2009, 07:59 -
Threaded Compression In VirtualDub
By Soopafresh in forum Latest Video NewsReplies: 14Last Post: 1st Feb 2009, 02:15 -
VirtualDub Smart Deinterlace filter vs Xvid option
By StealthKing in forum DVD RippingReplies: 16Last Post: 17th Aug 2007, 11:37
