I have always had luck extracting a wav or AC3 file from a VOB with DD audio. Yesterday I had my first VOB with DTS audio and couldn't extract any audio.
Is there a special setting in DVD2AVI for this?
Actually the newest version of DVD2AVI can extract DTS but I don't trust the D2V project files it creates. So use the newest version of DVD2AVI to get the DTS audio BUT then run the VOB files again through the 1.76 version if you need to use the D2V project file as the 1.76 version seems to work best but does not extract DTS.
- John "FulciLives" Coleman
*** EDIT ***
Please note that when I say the newest version of DVD2AVI can "extract" DTS audio I mean to say that it can DEMUX DTS audio. I do not know if you can DECODE the DTS to a WAV file. That is something I have never tried to do with DTS audio."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I did use the latest version of DVD2AVI and was able to demux all tracks, both AC3 and DTS. I did use TMPGEnc to encode the video only using the created d2v and got a "stream error" about 86% of the way through. Maybe I'll take your advice and use DVD2AVI v1.76 again to get the d2v file.
I do have a question. If I am creating a DVD, why would I want to decode the AC3 or DTS to a wav file? Why wouldn't I import one of these
streams into DVD Lab and maintain the audio information? Wouldn't all the surround information be lost upon decoding to wav?
Also, if my receiver is pro-logic, it couldn't handle the DTS anyway. Shouldn't I use the AC3 file so my receive can at least extract the pro-logic information? -
Well your original post didn't say you were dong this for a DVD and since so many people play around with so many different video types (VCD, SVCD, DIVX, Etc.) I was not sure what you were doing.Originally Posted by webbjs11
So if you are making a DVD then yes of course you want to use the original demuxed audio without making any further changes.
HELP for extract DTS or AC3 audio from MKV
By Riversound in forum AudioReplies: 5Last Post: 29th Jan 2010, 11:56 -
6-Channel Wav to AC3 and DTS
By kerpal in forum AudioReplies: 8Last Post: 9th Feb 2009, 10:10 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 18:42 -
extract entire ac3/dts audio track from a DVD
By shiet in forum AudioReplies: 1Last Post: 24th Feb 2008, 03:26 -
How can I extract AC3 audio from VOB files?
By Sean_ve99 in forum EditingReplies: 6Last Post: 1st Oct 2007, 05:56
