I downloaded a Divx file which has a screen size of 696x480 and framerate of 23.975 fps.
I'm trying to convert to SVCD using Tmpgenc's standard NTSC film template, but the Divx file has a strange distortion effect every 4th frame which I've never seen before. I believe it is called combing. Here's a screencap:
I read on another site that this is an interlace problem and could be solved using Tmpgenc's deinterlace settings. I've tried tests using every single choice available and they either don't work at all, or cause additional problems such as ghosting or even greater distortion.
Yet another site suggested not using any deinterlace method since this combing will only appear on my PC monitor, not on my TV screen when played on my standalone. Again, this was not the case.
So the question is, how do I fix it?
Tx,
Magwell
Results 1 to 1 of 1
dv to divx problem
By anajat in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2011, 19:27 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
DivX to DivX Convertion Problem
By Spiderm@n in forum Video ConversionReplies: 25Last Post: 4th Dec 2007, 05:15
