  1. CMZ
    Guest
    Hi, everybody!
    I (better: ffmpegX) created a 2 gig MPEG file out of a VOB. It was converted using quick settings (SVCD PAL) and bitrate 2500. Viewing that MPEG with vlc is possible... so far so good, but there qere no .img or .cue files produced
    the output file was movie.mpg
    now there are three files movie.mpg-1.mpg to movie.mpg-3.mpg, but how can I burn a SVCD out of them?
    I have tried to use the tools bar, enabling SVCD (.img) and splitting into 3 chunks, selecting my movie.mpg file. Clicking "author" results in the same. Can I convert the files with the command line tools manually?
    Thank your,
    CMZ
    Oct 2002
    Huntsville, Ontario, Cana
    Take a look in the guides section, there are several there on auhoring SVCD.
    Will
  3. Guest
    Use a program such as vcdeasy and create bin/cue image files and burn with vcdeasy or cdrwin or nero or alcohol 120% or any other program that can burn cue/bin files.
  4. Originally Posted by CMZ
    Make sure they're in a path without spaces or special characters in the file or folder names.
    Select the mpg-1.mpg in the first Browse.. field of the Tools tab. Enable the "Author as SVCD" checkbox only on the left side. Click the "Author" button. Repeat for the other two files.
  5. Guest
    Hi,
    i did that. ffmpegX tells me that it is ready about .5 seconds after pressing the "author" button, unfortunately without having done anything . the real path to my file is
    /Volumes/Portable/Movie/movie.mpg-1.mpg
    I tried both, creating .img and .cues but both don't seem to work
    CMZ
  6. CMZ
    Guest
    Hi!
    I finally got a solution for my problem:
    I did not get ffmpegX to create my SVCD image files, but I took those 3 MPEG files and created a disk image using the tool VCDBuilder. This works fine, although in an earlier version - I think 0.0.8 - it also worked with ffmpegX out of the box
    Thanks for all the tips I got of you!
    Bye,
    CMZ
