Does anybody already have some experience with Ulead DVD MovieFactory?
If so what do you like about the product and what do you dislike?
I am curious since I want to buy either one of them.
Ulead MovieFactory, it's almost the same as UleadPlugin1.0, but now supports multiple titles, multiple chapters, menu background image, menu background music, and changes thumbnail of buttons. Output to VCD/SVCD/DVD. It also provides a "ToolBox" which can capture video, convert video. I like it most.
For Pinnacle Express DVD, it provide DV capture function, scene cut dectection (to be chapters), menu templates, and the powerful "Customized menu" which you can change menu layout, number of button, button border, text font, text size, text effect, and menu background music. Output to VCD/SVCD/DVD. It is not so stable and slow when it convert DVAVI to mpeg. Pinnacle Express also support photo slide show but after burning a VCD, I found the photo quality is so bad, it seems that Pinnacle convert photos to mpeg video to be slide show (so that is why they have transition effect? I'm not sure.)
For a not so pro user, I like Ulead MovieFactory more, easy to use and not bad quality. But I think it should support photo slide show.
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 13:42 -
Ulead DVD Moviefactory 6 Plus (trying to get to grips after UDVDWorkshop2)
By dvdfever in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2009, 20:01 -
Joining in Ulead DVD MovieFactory - does it lead to worse quality?
By rosbif08 in forum EditingReplies: 2Last Post: 6th Aug 2008, 21:32 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 10:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 10:46
