Ok I'm stumped.
I'm backing up a DVD via these steps:
Using DVD Shrink (3.0 beta) and shrinking movie to 4.46gig in size (got rid of French soundtrack and subtitles) TOTAL NON-SHRUNK MOVIE IS 8+gb in size.
The shrunk files are on my empty second HD in my VIDEO_TS folder like I always do. When I click "details" in Windows Explorer, the files still add up to the above stated 4.46gb total size.
I use ImgTool Classic newest build (worked fine on other occasions so I know it's not the problem..I think) and create a .iso image file from the VIDEO_TS folder that has the shrunken files. I create a Target folder to put the .iso as well BTW.
When that's done the problem shows up.....
I open up DVD Decrypter, go to MODE, ISO-WRITE, and choose the image file I created. However, when I look at the file size to burn of the shrunken movie, the size grows 2+ gigs larger! something like 6.6gb total size...sure enough, when I go to Windows Explorer and look at the .iso file, it isn't 4.46, it's 6.6gb!?
Using this method worked fine this past weekend, but the last two attempts yield the same weird results.
Anyone have any thoughts??
Thanks!
Alf
Visit my Philips DVD Recorders discussion group HERE and my Home Theater site The Enormodome
Mystey solved!
The problem was with DVD Shrink 3.0 Beta.
I switched back to 2.3 and all went well.Visit my Philips DVD Recorders discussion group HERE and my Home Theater site The Enormodome
Cause a 3D Title to grow with time
By Anonymous8743 in forum EditingReplies: 8Last Post: 24th May 2010, 04:09 -
Suddenly Cannot burn DVD files to DVD-Rs
By Frogde3 in forum Authoring (DVD)Replies: 6Last Post: 22nd Oct 2008, 14:55 -
cant SUDDENLY play all video files, only audio!
By dwardwarbinx in forum Software PlayingReplies: 6Last Post: 7th Jul 2008, 12:34 -
ImgTool Files Too Large
By opieandy in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 21:08 -
suddenly can't play mpeg files!!!!
By BillW in forum Newbie / General discussionsReplies: 3Last Post: 14th Jul 2007, 19:45
