Hi,
I am building a new system, and eventually I'd like to archive my VHS tapes and my DirecTivo programs to DVD. But due to poor planning, I didn't figure the cost of a capture card/unit into my budget. So now I need a multi-purpose card to put into this box until I can afford something like a Canopus ADVC-100. But I'd still like to start learning about capturing and converting. Can anyone suggest what I can use in the meantime? My needs are the following:
-- Good Capture
-- Great hardware mpeg-decode for video playback
-- TV watching
-- bonus: good 2D/3D
I've been looking at the All-In-Wonder or the combo of a cheap video card/cheap capture card. (I don't know if I even need a TV tuner, since the DirecTivo is controlling the signals.) I'm hoping to spend less (make that MUCH LESS) than $150. My local computer store is selling an OEM AIW 8500DV with 64MB for $109. Are there better options? Most of my money is going into other components in the system:
-- P4 2.8 Ghz, 800 FSB & motherboard
-- 1 GB PC3200 DDR
-- 250 GB HD
-- DVD Burner
Most of these components have already been purchased or ordered, so I can't really downgrade anything to come up with more money for the card... If anyone can recommend a budget interim solution for my setup, I'd really appreciate it. Thanks in advance!
Spiffy
Results 1 to 1 of 1
What is the best capture card on a small budget?
By 707Gaming in forum Newbie / General discussionsReplies: 5Last Post: 12th Jul 2011, 06:42 -
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 15:42 -
Question why these high dollar BluRay players are not multi-system
By jimdagys in forum DVD & Blu-ray PlayersReplies: 3Last Post: 6th Apr 2010, 10:18 -
Software Encoding on High-End System
By tbradyjd in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2010, 21:36 -
Finding A High End Graphics Card For Laptop
By Nitro89 in forum ComputerReplies: 10Last Post: 24th Oct 2008, 22:31
