Sorry if this is the wrong forum, and will understand if its moved.
I have just entered the details of 108 mins dvd, in to fitcd for two 80min cd's. I split the time to give 54 mins on one 80min cd, and then this would be x 2.
It gave me a bitrate of 1889.
I entered a minimum of 500, average of 1889(as above) and 2400 as maximum in CCE, but I still ended up with a mpv of 1.55gb which is too big for two 80min cd's before I even mux it with the audio.??
Can anyone advise as to what they can see I'm doing wrong.
The film length is 1hr 48mins, which =108mins,and audio is unticked.Its for SVCD
Thanks very much
Raider.
<font size=-1>[ This Message was edited by: Raider on 2001-10-13 17:25:29 ]</font>
Probably it isn't too big, if you encode the audio @128 kbps. You can fit up to 800-807MB on a 80min CD-R.
@Truman,
Thanks mate, I have encoded the audio at 128. Didn't realise you could get 807mb on 80min disc, just thought it was a set 700mb/80min disc and 650mb/74min disc.
You learn something new every day
thanks again, I'll give it a burn and see what happens.
cheers
Raider. -
Nope,I couldn't burn it, loaded an 80 min blank disc with burnproof ticked (my burner supports it)and Nero told me the media wasn't big enough???
I must be doing something wrong in FITCD,but don't know what.
How can i reduce the file size, I thought Fitcd gave pretty good readings??
Would I have to reduce the average or maximum bitrate
cheers Raider. -
FitCD never failed for me. And according to FitCD 1889 (average)+128 is OK. But I use to author with VCDImager and burn with CDRWin. Maybe that makes the difference.
Honestly, 1889kbps is calculated quite close to the limit.
How to reduce the filesize? Either cut a unwanted minute or reencode at a lower average bitrate. -
Is there any settings I might be checking and I don't need to mate, which is causing the problem??
I honestly can't see what I'm doing wrong, unless there is a setting in CCE that I am overlooking???
HELP!!
I think you would be best suited to use this proggy as a guideline and not for final scripts and numbers. That is what i do.
According to my calculations your movie needed to have an average bitrate of 1476 to fit on 2 cds.
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
fit 3 movies to dvd5
By thecrock in forum Newbie / General discussionsReplies: 9Last Post: 19th Jul 2008, 14:00 -
auto fit
By roystheboy in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2008, 05:23 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 11:46 -
Help to fit two DVDs into 1
By heretic1 in forum Authoring (DVD)Replies: 1Last Post: 12th Jun 2007, 22:57
