I have tried doing this 3 times and it errors each time.
System.IO.IOException: The process cannot access the file "_Football.Factory.\ff_1_tof.wav" because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.File.Delete(String path)
at _S_VCD2DVDMPG.210ff09a2516b1a7.fbd359f29063c517(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
The process cannot access the file "D:\DVDz 2 burn\12.07.03_Football.Factory.READNFO.2004.WORKPR INT.SVCD_ToF\ff_1_tof.wav" because it is being used by another process.
Not sure. You could try using ffmpeg as the audio encoder. Select this in the options form.
VirtualDub Audio Error
By aaxpers in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2012, 08:01 -
AVS2DVD audio error
By Motinha in forum Authoring (DVD)Replies: 13Last Post: 25th Dec 2010, 22:51 -
audio error!?
By lainexperiments in forum Newbie / General discussionsReplies: 2Last Post: 3rd Aug 2010, 17:20 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 14:39 -
AutoMKV audio error
By Kalash109 in forum DVD RippingReplies: 6Last Post: 4th May 2008, 11:57
